Running then just stopped!
General discussion area for the L30-chassis Altima
ghux
Car: 1998 Altima 2.4
Running fine and just shut down. Will turn over but won't fire. Checked Distributor and all is good. Pulled Valve cover and upper timing chain cover. Chains appear to be tight and good. No pieces in oil pan. Any Ideas?
Timothy S
Car: 1998 Nissan Altima GXE, Auto RE4FO4A, KA24DE Engine
Is the fuel pump running? Any other things not working? This sounds to me like an electrical problem, perhaps an ignition relay, the ignition switch, a fusible link or a fuse. The recent bad weather is just right for electrical/water problems.
telcoman
ghux wrote:Running fine and just shut down. .... Any Ideas?
Are you getting spark?
Are you getting gas?
Are you getting Air?
Clogged exhaust?
Telcoman
Timothy S
"Will turn over but won't fire"
We know there is no spark, but still need to ask the Air, Fuel and sensor questions.
telcoman
Timothy S wrote:"Will turn over but won't fire"
We know there is no spark, .
If there is no spark you need to troubleshoot as to why.
Start troubleshooting here
http://www.nicoclub.com/FSM/Altima/1998/el.pdf
See page EL 24
BTW your theft warning system can prevent the vehicle from stating along with a blown fuse.
Get yourself a voltmeter and do some testing
Good luck
Telcoman
Return to “2nd Generation Altima Sedan (1998-2001)”
