Lmao ...Chris do you d!ck around with cars for 3 hrs before you get serious???? I dont, I usually get it serious right when Istart on the car and have it figured out with in 10 mins...................
then I d!ck around for the next 2 hrs and 50 mins before I call the customer and tell them whats wrong.
Guy your car had substantial front end damage from what you described plus you put all kinds of aftermarket parts on it. perhaps you should start looking around where the car was hit for a short, Your failure shouldnt be that hard to find now as the wire will likely be mush from you allowing a higher amperage then the circuit is deigned for run through it [the fuse ladder you went up] you could of set your electrical on fire when you did that. look in those areas involved in the accedent for melted wires. and definitly get your self a service manual so you can test the circuits.
