C-Kwik wrote:If its oil that is smoking, it will smell somewhat noxious. Coolant tends to smell a lot like coolant and if you are close enough to it, it will feel humid. Fuel smells like fuel.
Oil can smoke a white color. I'm not entirely sure when it does this, but both times I had a turbo seal failure, I got white smoke. My speculation is that it occurs in cases where the oil is heated to the point of evaporation but not burned. I'm fairly certain oil only leaked passed the tubrine housing seals as I found no indication that there was any oil being forced through the intake.
The reason it only happens when idling, is because of the pressure differential across the seal. At idle, there is going to be very little pressure in the exhaust. The higher pressure in the center-housing will allow oil to move past the seal if it is partially sealing. Under boost, the exhaust manifold will be at higher pressures and will either provide an equal force against the oil pressure, be higher than the oil pressure or only allow a very small amount of oil to leak passed the seals. Depends on how bad the seals are and what kind of pressures are seen on both sides of it.
In my case, I was able to prevent it from smoking by leaving the A/C on. The higher RPM's actually prevented it for me. Each person's situation will vary depending on how bad the seal failure might be, the oil and exhaust flow rates. Assuming it is indeed a turbo seal failure, fixing that would be the only sure solution.
