Running ruff at highway speed.
BoomSlang240sx
Car: 1991 Nissan 240sx
I have a 1991 240sx with a KA24de and I have just got done replacing some stock stuff with aftermarket parts. Whenever I was putting things back, I read that I could remove my EGR system and there would be no problems.
Here's what is wrong: my car runs fine until I get it up to 60-65mph, then it will jerk and sputter like it is not getting enough fuel in it. I was wondering if, since the engine was not getting that little bit of unburned fuel that it was used to, was it not pushing enough fuel into the combustion chamber? If not what could it be?
Any help would be nice.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
did you block off the hole where the egr used to be on the intake?
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Are you getting any codes?
BoomSlang240sx
numbnuts240 wrote:did you block off the hole where the egr used to be on the intake?
I did this with a small aluminum plate. There was a wire going to a box on the driver side of the engine bay. I removed the box and tucked the wire under, I didn't know if there was something that I needed to do with that?
BoomSlang240sx
scotty-2-forty wrote:Are you getting any codes?
I am not sure what you mean? Like lights on my cluster?
Sorry I am new to all of this.
scotty-2-forty
Maybe these will help ...
BoomSlang240sx
Thanks I will try that first. Where did this come from? Was it a Manual?
Dattebayo
You probably just forgot to block off the vacuum line after you removed it.
