hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Thu Mar 31, 2005 5:16 pm
so i don't really know what to search for on this one, because my problem's not completely related to the idle. i haven't tried to tackle the problem just yet but i wanted to see if i can get ideas before going into it...
i just installed my fmic, and then the problems started. blocked the iacv off a while ago and the car ran fine for a few months, and then a few weeks ago i installed my fmic and it started with these symptoms...so anyway here's the symptoms: the car runs kind of rough, like hesitates and what not, under certain conditions. these condtions are:1) at idle just after start up, but once the car warms up it stops running as rough. it runs as if it is missing a cylinder, but not on every rotation... it's kind of irratic... it'll miss a few times then run okay then miss and then okay and it just does it at will, not really a pattern to it.2) at low idle throttle. what i mean by this is when the throttle is not open very much but is held at a constant place, for example when cruising on the highway, or when cruise control is on.
it has been somewhat consistant in happening just about every time i start the car, as long as it's cold usually, but it doens't have to be cold, and it doesn't do it much on the highway anymore... when i first installed the fmic it had problems on the highway because all the piping wasn't hooked up well, since i was ripping it out the next day to replumb everything. i'm still not completely finished with the plumbing because i am having my bov flange welded on to one of the u bends right now. i know something is just wrong in the install of what i just did, because the car was running perfect until i installed my fmic. i'm sure i can figure it out but any feedback would help because i do need to fix it soon, and i'm always pressed for time... i want to try and tackle it this weekend, if i have the time.
thanks for the help.
