ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Jul 11, 2004 10:23 am
my car will run rich when I 1st start up... it is normal since the ECu is running on a preset program until the Tstat brings your engine up to operating temp...
...& finally goes into "closed loop" using the oxygen sensor as one of the main feedbacks to lean/enrich the air:fuel ratio as needed
some other member confirm my theory that I learned from auto class ages ago?
in addition, if you have your charcoal canister system still working, the excess fuel vapors are trapped there 'till u start up the car again, which is fed back into the intake & burned off...
