I realize that this may be obvious to some, but I thought I'd try to give something back to those of us in the CA community who are still learning.
To make an extremely long story short, my CA was running extremely rich. I got a different ECU which helped, but I was still running very rich. Those who care can read about it here:
zer...00969
Then I came across this thread about wiring up the knock sensor:
zer...00969
The CA swap I bought came with the knock sensor, the knock sensor wire, but no plug, so I ran the car without the knock sensor connected. In the above mentioned thread I read that a 1 meg ohm resistor will trick the ECU into thinking it has a knock sensor. I hooked up one end of the resistor to the sender wire and the other to the firewall, and sure enough it started to idle at about 14.7:1 (stoich).
So my problems appear to be solved. I took the car for a drive and it's about 14.7:1 on the highway and 12-13:1 when I'm boosting. (I'm running 10 psi.) One issue I'm having is that after I came home it was idling at about 12-13:1, but since this is only at idle, I'm not too worried.
Anyway, I've very happy today.
Thanks to everyone who tried to help!
PS If you don't have a pigtail, you can use shielded wire and a splice connector as a plug. I know it's ghetto, but it worked for me:
