r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Wed Sep 08, 2004 7:04 am
you need something to lean out those 450s unless you are making enough boost to use all the fuel. maybe your o2 sensor is bad, causing the ecu to run rich as shiznit under boost to protect the engine? the o2 sensor thing happened to me, got the same problem. i was running a 6 to 7 a/f ratio. make sure the o2 sensor is getting the correct voltage too, it was the cause of my o2 problems (as well as the sensor itself, the tip of it kinda broke off and got lodged in the cat).
by the way, how do you like that multi checker? i wanted to get one but never really knew if it was worth it. they dont cost too much if i remember correctly.
- tim
