running rich
Rixmax1992
Car: 1992 nissan maxima
1991 Q45 no longer an (a)
T.C. guides, tokiko blues, eibachs, active rear sway bar.
Hello everyone: I have a 1991 Q45 no longer an a with 223K. I changed my plugs today with NGK platinum lazer cut. When I pulled the old plugs out they're gas fouled. I recently tried to get it smogged but it failed due to hydrocarbons. I tried the trick getting the cats red hot but that didn't work this time. The smog technician said since I was close to passing try and put some new plugs in. Should I adjust the idle mixture. RixMax
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
you can't adjust the idle mixture.
you could have intake air leaks which would cause the STFT to read lean and therefore the ECU would call rich.
check your O2s, check both STFT and LTFT.
what did your NOx read?
hell, post up your report if you can.
Q451990
:gapteeth: I learnd'd something... STFT = short term fuel trim.
