Check the injectors.shortmorgan wrote:My sohc is continually running rich. I've cleaned the MAF.. I was running it without a therm for a little bit but it now has one and is running and idleing fine.. It shoot a little carbon out the tail pipe "sometimes" but not most of the time.. A little white smoke as well when I get into it...
Why would you open the radiator cap when the car is running?shortmorgan wrote:Side note.. When your motor is running smooth shouldn't you be able to open the radiator cap and then crank, and make sure the coolant is flowing well? Mine is not flowing well.. It shoots out of the cap a little.. Any and all HELP is appreciated.. and REV D I searched and I only found 1 thread about running rich.. Thanks..
Not .. I typed it in wrong, so for4 anyone I mislead (on accident) I searched once again and found alot.. So thanks..Wc240 wrote:1 thread about running rich? try again.
check the basics. injectors(id do later down the line) CTS, O2, spark plugs, air filter, cap rotor... etc
dont pull the cap off when hot, theres a reason they make warning stickers. the reason you open it and crank is while your checking a headgasket issue
