JDMSIL80 »
https://forums.nicoclub.com/jdmsil80-u30772.html
Sun Jun 25, 2006 4:23 am
So I took my car to the dyno yesterday and have the shop find out where the possible boost leak is. They used soap with water and sprayed the entire pipings while rolling the dyno at high boost. After an hour of inspection, they confirm there is no boost leak anywhere. The boost is steady and stable.
However, we found more details about the richness problem. Not only when boost the fuel would become very rich (10s), it will be also goes rich (10s) even in vaccuum when you tap on the throttle after each shift, which is before you even hit boost! Because it goes so rich during gear changes, the car would sputter for a few seconds at each shift and really destroy the driveability. Seemed like there's a problem in reading air flow, as the car doesn't like sudden changes in air flow and would go very rich if happens. So the shop suggested me to use another MAF sensor and see the differences, as it sounded like the most logical step to take.
After much headache I decided to buy a Re-manufactured MAF from local parts store for $300, which includes 1 year warranty. I just finished swapping the MAF and took the car out for a spin, but guess what, the problem is STILL there!!
So it is NOT the MAF sensor, O2 sensor nor boost leak. I'm running out of ideas, the gas mileage is killing me. Can someone suggested me next step, I will try the spark plugs, but I dont wanna keep running in to the brick wall..
