S12_hybrid »
https://forums.nicoclub.com/s12-hybrid-u41151.html
Wed Aug 08, 2007 2:36 am
Just for the record:
I built a boost leak tester out of a piece of PVC tubing, a screw in shrader valve (tire valve), and a silicone coupler.. I pressure tested the intake system and discovered a few minor boost/vacuum leaks. After amending these leaks I ensured that my water temp sensor connector (which was crushed) was not shorting out.. A few inches of electrical tape later and I moved on to the TPS. I extended the connector with some wire leads and tested the center pin voltage with the ignition on as I rotated the throttle plate. It read from .35v to 4.2v which is almost perfect.
Then I loaded in my fouled plugs again so I could start it and look for fuel leaks and spray soapy water on all intake couplers. Started it, and it sounded alright. After reaching operational temp I took it out onto the road and immediately noticed that coming off idle was much crisper and I didnt have to rev it up and dump it just to get enough torque to move it. With first gear selected I let the clutch out..
This was my first drive in an RB powered vehicle.. This thing took off like a rocket. I have never felt such savagery. The whole car is brutally to the point and snickety in how it does things.. It's more than a little bit evil - it is satan re-incarnate....
-Dan
