piston »
https://forums.nicoclub.com/piston-u44488.html
Mon Jul 31, 2006 3:55 pm
I know this topic has been posted before, but not everyone has the same problem. Here is mine
First problem I had was a bad ignition coil and distrubitor. I have replaced those and timing is dead on.
Now my problem is that every time I go to start, I seem to be flooded, I can clear it out by disconnecting the injectors and restarting, then it will die. I then reconnect the injectors and it starts just fine. Now that it is started I have white smoke, which I think means it is running rich.
I read somewhere you can check the voltage at the o2 sensor to see if the engine is lean of rich and it reads at .93 volts. I assume this is a reading of being rich( please correct me if wrong).
I would really just like to get the car running with no problem, if that is possible.
Also, the car is a 91 240sx / RMS13
Thanks,
Jason
