ray666 »
https://forums.nicoclub.com/ray666-u75232.html
Thu Apr 08, 2010 4:18 pm
well...i thought i had all the bugs figured out. anyways the car will run fine at the start then run rich til it warms up. it will run fine for 10-15 mins then out of nowhere it will dump gas. then sometime later the a/f will be great again. i cleaned out the plugs which helped a little. i checked for boost leaks and everything is super tight. the injectors are huge 785cc, i checked for leaks there and nothing. i got it narrowed down to the maf or fpr. does anyone know if nismo fprs go bad? i noticed when the car is idling rich the fpr gauge is flicking back and forth. the maf wires got quick disconnect plugs, i guess i should solder that. any help would be awesome.
