Running rich & ALOT OF MODS
TonyStarks29
Car: 1994 Nissan 240SX Convertible w/ SR20DET
Ok i have a 1994 240sx Vert with the Sr Black top my mods are
Gt2871r740cc injectorsFMIC Tuned ECUHks knock off bovZ32 Maf
My car is running rich at idle i figured it just needed a tune..
my car was idling at 1300-1400 rpmafter tune im running1-1200 rpm the tune deffentily helped it go down but now its still up there
i cant seem to figure out the problem i've tried to reset the throttle, checked for vacume lines im thinking maybe its the Maf but i doubt it...
could the 740 injectors be too much on my car? (wouldnt the tune fix that)
any ideas would be great...
schanne
Car: 93 Hatch-Sr20
The knock off BOV could have leaks. I would change that asapJust a thaught....
Kalypso
check all the vaccum lines again, for a leak,
or put you maf right before the throttle body for an accurate read.
S14toRPS13
ECU tunes usually run rich. You'll need a piggy back fuel controller like the Apex'i SAFC to fine tune.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Have you adjusted the idle screw?
TonyStarks29
yeah i ajusted the idel screw... it didnt help
