caspers_240 wrote:u don't remove ur stock 02 sensor... the wideband should be placed more downstream the exh.
what he said unless you are running standalone and a wideband that is compatible with said standalone
most wideband companies say to put the sensor 12-36 inches away from the turbo on boosted cars... (idk where you would measure the 12-36 on an n/a car)
as far as the AFR's.. cruising should be somewhat lean (afr greater than 14.7:1) at WOT however, depending on the mods... should be slightly rich (below 14.7:1) anywhere from high 11's (boost) to low to mid 13's (n/a) iirc
if the motor is stock... idk what 'normal' is
