Running rich 240
xstanger
Car: 94 240 conv, 91 240 coupe, 90 coupe, 89 hatch
Car blows black smoke and fouls out new plugs with gas in no time. Any ideas of what the problem may be? 1990 240 car.
kouki munster
Car: 97 base 240
Sounds like a bad injector(s) or a fpr.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
also check coolant temp sensor and its connector.
xstanger
Where is this sensor located? Thanks
180fan
Car: 89 fastback
Look for the lower radiator hose. it'll take you to the thermo housing. Behind the thermo, you should see two sensors, one with a single wire and the other with two wires. The CTS is the one with two wires.
ACESXX
Pour some gas treatment and injector cleaner together and let's see what happens it worked with my car!
