The ground cables are coming out of the injector harness, jupp.Try to mount an extra ground cable from manifold to chassi, a regular cable or a starter cable for test.Smurf6x6 wrote:O2 sensor is new from nissan as is most of the sensors cause i work at the dealership. I Have 300ZX TT plugs installed, also new. Stock ecu, stock maf. Both ecu's I tired are stock along with the other maf I tired. I'm running out of ideas. I been an apprentice at nissan for 2 years now, I really don't want to bug the techs but I'm running out of ideas? Where is this ground located swedish? I re-wrapped the harness, I may have wrap that groud by accident, you never no. Is it one of the grounds by the injector harness? I got 2 there I grounded on the manifold. The injectors are the yellowish brown colour. I had 2 set cause I had 2 motor set one AWD which I installed and a rwd one for parts.
