Joe, not to be a D*** but Hes right -sort of... - In a closed system, the coolant is NOT supposed to boil, as there shouldn't be air in the coolant system. The reason its pressurized is to effectively raise the boiling point of coolant, so it does NOT boil. The radiator cap only dumps coolant if the max pressure the system is rated for is surpassed. For that to happen there has to be something malfunctioning in the system... and it only turns to steam as it hits open air/atmospheric pressure...Joe wrote:
what the f*** are you babbling bout?
no. once it boils thats it, the large majority will escape the system and never come back. it leaves by way of bypassing the radiator cap because of the pressure relief valve.
and you need to drop your little know it all attitude, newbie. i will not tolerate you being a jackass to other members.
Think of a boiler system for a steam engine- as temp goes up so does pressure, right? If the pressure is contained, the temp of the water can greatly surpass the 100degress C that water boils at...
