S13Sil-line wrote:If you put it in gear and let the clutch out and record the speed the car is going with out putting your foot on the gas so the motor tech. sould be idling in gear. Or you can put the rear end on jack stands and put it in gear and record the RPM and speed with closed throttle. Does that help?
you can't really idle in gear, as the motor will die out, because you need to step on the throttle to keep the motor running.
even if you are already rolling, and step on the clutch pedal, the rpm should settle to whatever you set the motor to idel when it's in neutral.
here's some info on setting the idle, if you need : click me
