HolyShiznit »
https://forums.nicoclub.com/holyshiznit-u7729.html
Thu Jan 20, 2005 11:46 am
Well plug readings and wideband don't lie, car is just running stupid rich in boost. I have already checked my intercooler piping/couplers for leaks and there are none. I am running a JWT ecu setup for Z32 MAF, 52# injectors, and 14.7psi/1 bar. The engine has about 1k miles on it since being rebuilt after it ran lean and I popped three pistons. Only things that were changed was I removed the butterfly valves and swapped heads (ported and polished). I also have a Tial 38mm external wastegate that has the 1 bar spring in it.
It has trouble maintaining freeway speeds, it starts ....fluttering is the only word I can describe it and stumbles then I let off. The boost rises to .4-.6 bar then flutters, if I let off and slam throttle 100% back down then it pulls through, but runs stupid rich. Around town it is normal but mid throttle/spooling it sometimes does the fluttering, stumbling thing too. I am at a complete loss. It also seems to be running lean/high EGT's before boost. Fuel Pressure is fine and the fuel pump is in good working order, the MAF is fine too (I checked voltage and even switched my spare out just in case). I am running a draw through open atmosphere Greddy Type-S bov but I dunno if that could be the problem. I normally don't ask people questions on these forums but I am at a loss and could really use some help from guys with more experience than me.
