First off, hello, I'm new to this site though I've looked at several posts when they've come up under my searches. I'm not particularly new to the Z. I own a 1986 300ZX that I've had for almost 5 years and have done almost all the work on it myself, and I bought a 1992 300ZX n/a 5 speed a little over a month ago. It's straight piped- I don't know what brand mufflers the p/o has on there.
From the time I got the Z32 running up until just a few days ago it would always idle high, around 1200-1500rpm, but it ran great. I followed the instructions I found here
http://www.nicoclub.com/archives/adjust ... level.html to adjust my idle. Everything seemed to go well. I walked around to the back of my car after adjusting the idle and found it was splattering soot and water onto the ground as it idled (which I had never noticed it doing this before). While driving it, the exhaust had a different sound to it and the get up and go was practically gone. I brought the idle back up, but the car was still running sluggish. I bought a stethoscope and listened for the injectors, which were all firing. I tried testing the fuel pump, but I don't think the autozone tester I had was working properly since it was giving me 0psi while either priming the system or actually running the car. I had noticed the fuel pump was making some loud noises, then stopped making noises all together. I ordered and installed a Walbro 255 today- the car starts right up, but it's still sluggish. I've run codes on the ECU and got a 55. I don't know if it could be clogged mufflers, timing is off, or if there's some other gremlin lurking in that car. Any insight would be helpful. I don't have a timing light at the moment, so I can't check timing that way until I can get out to a parts store. Are there any other systems I should be looking at that could cause poor acceleration?
Thanks in advance.
