david gussie »
https://forums.nicoclub.com/david-gussie-u55820.html
Fri Feb 02, 2007 2:14 am
Also, when i first started changing wires many years ago, I messed up even though the wires were different lengths. Back then the wires were made of carbon and broke inside very easily. I don't know how to use an electrical Ohm meter, but you can send current through each wire to see if they are working properly. sometimes they crack on the inside as you install or remove them, their is no way of telling. Check all the connections to see if you might have brushed up against something and loosened a connection some where. I did all that over the years, LOL
