running on 4 cylinders and code 34
aidanair
Car: '90 Nissan 300ZX TT
'93 Nissan 300ZX N/A (SOLD!)
well, my number 5 cylinder and number 4 cylinder arent firing... the problem came out of no where while driving one day... ash powers installed my new 740cc deautschwerks injectors, and after swapping spark plugs and coil packs, i am beginning to get the feeling maybe the injectors are at fault (also since there is a strong gas smell)
after swapping around plugs, i threw ecu codes and got a code 34... could this be related? i also noticed a tapping sound that sounds like possibly a bad bearing or rod, but im unsure if the code 34 is related. thanks for the help guys!
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Sounds like a fuel leak or bad injector. You may be detonating because you're not getting fuel in that cylinder, or not enough. Could also be a bad o-ring seal on the injector.
aidanair
i agree, i think i'll pull the plenum this weekend and see where it takes me, thanks man
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Also look at the isolators on the bottom of the injector. They can get pinched during installation and leak, cause the car to run lean.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Code 34 is injectors. Visually inspect the injectors, then ohm test them. Should come out to be 10~14 ohms, IIRC.
If that all checks good, it may be the harness. Also inspect the connectors, as the Z32 is known for its corrosion prone tendencies.
BigTDogg (MA)
Ace2cool wrote:Code 34 is injectors. Visually inspect the injectors, then ohm test them. Should come out to be 10~14 ohms, IIRC.
34 is not injectors, it is detonation sensor. It's possible it's a faulty det sensor harness, but I think his 34 problem is independent of the dead cylinder problem he's having.
