DammitBobby wrote:Is your setup low impedence or high impedence? If you are using a resistor pack I would start checking things with a volt meter. What is the impedence of the bad injectors compared to the working injectors?
high-impedance.
S13FX wrote:It's not the injectors.
it's his whole Cap and Rotor assembly I keep telling him but he won't listen.
In other words GET A NEW DIZZY.
^damn this guy has no clue wat hes talking about....hahaha j/k, ill order a new distributor assembly next time i'm in indiana. Is there a test I can do that will tell me that it is the distributor for sure?
nelson8708 wrote:clean the injector clips and the injectors where the clips go. I had a problem where my car started to act weird and hesitiate when on the interstate after swaping fuel rails. Turns out that the injector plugs had corrosion on them and every once in a while cylinder 2 would go dead. Get the car running the wiggle the 3rd cylinder injector clip on the injector and see what happens. I would take the clips off anyway and clean them just in case. Hope this helps
I already replaced the injector clips. I also took all of the injectors out while they were still hooked up and cranked the car. All of them sprayed evenly.
