vvaffle »
https://forums.nicoclub.com/vvaffle-u23443.html
Wed Oct 26, 2005 5:09 pm
Both methods that hudy said should work. The problem with listening on the screwdrive is that if you have any other ticking (like timing chain hitting the guides) it will be hard to distinguish noises. I did this and it seemed like every injector was ticking, but I knew that the #1 didn't work.
Using the resistance to check would work great if the injector is totaly broken. If it's just dirty the resistance might show up fine. A good injector has resistance somewhere in the teens. Anything outside of that, it's most likely not fixable without some serious work (not worth it, can get a stock injector for cheaper).
As far as getting the injectors out, I wish I had a picture. structure240sx showed me this trick. Get two flathead screwdrivers; one may be enough. Now, you see the part of the injector where the wire plugs into. Stick the thicher flathead under that and against the metal rim of the hole that is right bellow it. Now instead of moving the flathead up and down, rotate it in place so only one side of the tip goes up at a time and the other side is pushing at the part bellow it. Do this for a while, you might be able to get it out just like that. If not, while you are doing this, some space around the injector will show up. Stick the other flathead in there and pry it out.
If this doesn't make sense, let me know and I'll take a picture.
PS. I knoew you responded before I finished writing this but it took a while to write and I refuse to delete it.
