LowFlying720 »
https://forums.nicoclub.com/lowflying720-u240261.html
Wed Jul 22, 2015 3:15 pm
Hello
I Finally got back to work on the truck.
Ignition checked good.
Carb has needed work for a long time, replaced stock with Weber.
Did compression test:
#1 145
#2 150
#3 35
#4 30
Pulled valve cover to see if somthing simple and easy to fix had happened up top. No such luck. Pristine and everything in order.
Then I gave the timing chain a push and on the non tensioner side it's just flopping in the wind.
I tried to look down the hole at the tensioner and see if it broke or just came loose but I really can't see much down there.
So my question is: Could a tenstioner failure/slip be the cause of my issues (rough running with knock and/or low pressure in the back 2 cyl)?
Also is it possible that the tenstioner came loose and allowed the chain to jump a cog?
With this coming on suddenly and no perf degrade prior, I'm supprised to see 2 cyl go flat like that.
Also I just finished moving and my manual for the truck is still packed away somewhere. Is there a link to the FSM or a good tutorial on timing chains?
Thanks for your help
