evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jun 15, 2007 6:08 am
well if idle quality is good then I'd strongly suspect the afm, as for articles I'm not aware of any, it cooul dbe a bad afm in which case no amount of adjusting will help, and if the idle quality is good then it likely won't need adjusting but with the cover off, move the vane a few degrees each direction with light pressure of your finger, then rev the motor and see if ti helps at all, if so adjust the gear in that direction a few teeth at a time
