Running lights not working
freed1992
Car: 1990 Nissan 300zx
Alright so I just bought a 90 300zx n/a. I noticed that my running lights stopped working completely. The only thing that worked was my high beams. So i checked the fuse panel by the clutch and replaced the top row 3rd fuse from left. Well as soon as I turned my lights on again the fuse burnt out. And i was reading on here and someone had a similar problem but he unhooked his cd player. I did that and my lights work fine but now I'm stuck. Any help would be great. Thanks guys.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Welcome to the forums and to Z ownership!
I would suggest checking grounds and checking the wiring harness for any cuts. There is a large ground by the battery. There is one on the driver's side down past the fuse box, and two on the plenum.
