nissantech171 »
https://forums.nicoclub.com/nissantech171-u157161.html
Fri Mar 26, 2010 4:36 pm
well if your bulbs filaments keep blowing i dont know what too tell you maybe use oem bulbs, or you are getting grease or oils from your fingers on them, also if you dont plug the connector on all the way also it can cause the bulbs to blow. if your bulbs arent blowing its just a matter of them not comming on theres many things that could be at fault. first i would check your fuses under the dash i dont know if there are any fuses there for the lights but check in your IPDM if your looking in the engine bay to the right by the battery there is a black box type thing if you unclip it you can turn it over and there are fuses in it check all of them there. also to the left of the engine bay there is a set of two relays for your headlights.turn your lights on and give the relays a tap if they come on you found the problem. its hard to tell you not seeing the car good luck let me know what you find
