None of boxes under the hood describe tail lights, and every thread I've come across says they're under the drive side dash.blacksrjdm wrote:Look at the cover on the fuse boxes, find said fuses in the description on the fuse box covers and where they are. Remove said fuses. Replace with new ones that are identical to the ones you remove. Really really really the dumbest question I have answered yet...
It is in that picture. It is either room lamp, light control, cig/light."meter" is definately the cluster. This is completely idiotic. I'm done.
evad wrote:Sorry, but here is a side
Is it normal if the clock on my gauge cluster stays on after I turn off the car and the key is out of the ignition?
This is my first nissan, so I'm not sure if this is a normal nissan thing.
