VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Aug 13, 2023 6:50 am
There's no direct link and no relays involved, and the running lamps only have a direct connection to the battery through the combination switch. But, the illumination runs off the same fuse as the running lamps, and those wires run all over the cabin. So I'd say you're most likely looking at a crossed circuit someplace in the cabin between the fuse 13 circuit and the illumination circuit, which is then back-feeding to the running lights. Could be something in the Timer box, those are spaghetti and interface with both the lighting system and some of the accessories.
