DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Mar 17, 2004 7:40 am
You can't take resistance readings on a complete circuit! You'll damage your meter. The voltage reading is the only useful one AFAIK. Not sure what it should be, maybe the manual has nominal values at idle. Only take resistance readings on isolated, disconnected hardware...i.e., unplug the MAF first.
