SRraider »
https://forums.nicoclub.com/srraider-u43273.html
Mon Dec 04, 2006 1:22 pm
To give you a little backgroud info here, I have a 92 s13 hatch w/ a redtop sr swap and 5 speed conversion. I have the stock sr maf, 300 zx fuel filter and walbro 255lph fuel pump. Well I've been having idle problems for a while now. Car would run fine when I started it up cold, but if i started it up after it was already warm, it would sputter at idle, dropping to 400-700 rpms. Well today I installed my AEM air/fuel gauge and wideband 02 sensor. When i start my car up (after its warmed up) it idles low still and my afr is off the gauge, well above 18 afr! When I drive it, under boost it drops down around 12-14. Any ideas guys?
