yourmomsrps13 »
https://forums.nicoclub.com/yourmomsrps13-u30742.html
Wed Aug 16, 2006 7:13 am
about a week ago my car started sounding like it had some heavy duty cams in it or a 12a rotary. also while im driving and i come to a stop it randomly jumps up to 2000-2400rpms and just stays there. so i tested and replaced the TPS because it was .10volts off and i had a spare but that changed nothing. so then i thought for sure it was the MAF so i cleaned it and that changed nothing, then i replaced it with a buddys, still nothing.I got ahold of a AEM wideband and tested my car at idle with the safc2 set at lowest throttle adding 16% more fuel then i should and the gauge reading was off the charts lean so i turned her up to 50% added fuel and she just barly was on the gauge reading lean, but sounded smooth and much better(also raised my idle to about 1500). when im driving i was stoich.i have a new walbro 255, new z32 fuel filter,stock injectors,stock FPR, t25 from a sr20 ka24e MAF
idk what to do for diag. im thinking i could have a bad fuel pump, cause it is a bit loud and i here it drop when i come to a stop. what can i check guys?
thanks
