MATT41178 wrote:OK
I have had my car running for almost a year and I just took of the cat for some drag pulls, It suddendy goes really lean at idol, I have a JWT ecu and SAFC, even whene I change the settings on the safc it will still leant out really bad at idol unless I feather the throttle a bit and some times it will take about 30 seconds to get it to run right at idol some times it will lean out and die, also while I am crusing the AFR's are unstable 14.3-15.8 it never did this before I took of the cat, I also ran without the cat after it was first rebuilt and turbocharged and It was fine running very solid at idol,I have tried to reset the de cel on the safc and still having this isuue,
Any help anyone can offer would be appreciated
My car was hitting high 17's/low 18's at idle after the flex pipe that ran from the downpipe to the EGR valve broke...but idle was the only A/F affected; everything else was rock-solid. But it also never came close to dying, even with the A/Fs that lean...
Cruising in full vacuum you should be at about 21:1
Try putting your cat back in to see if it runs the way it did earlier...although just removing a cat should not cause what you're describing...(it shouldn't cause anything actually, except maybe a CEL if your 02 sensor is disconnected)
