Running larger size tires on stock 2016 QX80 Limited?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Indy680
Car: 2016 Infiniti QX80 Limited
I currently have 275 50 Pirelli All Seasons on factory 22", 2016 QX80 Limited and they are coming to the end of their life.
I want to replace with A/Ts and possibly larger. I am also looking at 33 x 12.50s.
Anyone running larger size 22s on stock configuration?
Looking for ideas.
Thank you in advance!
Reason: Revise Title
Generally, it's not a great idea to go too much bigger in overall diameter.
However, your current OD is 32.9" and the 33x12.50 is 32.5" (well within the acceptable variation).
So, that won't be a larger tire (height-wise) but the REAL problem you'll run into is rim width.
Your current tires call for a 8.5" wide rim, and the 33x12.50 calls for a 12.5" rim width. Obviously, these are suggestions, but that's a 4" width difference, so unless you have aftermarket wheels and a body lift, the "truck tires" are going to pose a problem (if you can even find a shop to mount them).
Here's four good A/T tires in your size that should accomplish the goal: https://www.tirerack.com/tires/TireSear ... NpDtsH7tOn
Return to “Armada Forum / QX56 Forum / QX80 Forum”
