Running kinda funny under boost, revs like crazy
invain
I just recently got my 240 finally running correctly so of course I've been raggin on it a little. I've noticed something strange however when I get into boost. It's really hard to explain, might be easier if I took a video or something, but I'm pretty sure this isn't normal.
Car starts building boost fine between 2500 - 3k rpm's. Accelerates normally, everything seems normal untill I get to 6 or 7 psi. Once I reach a certain point however, the car seems to rev insanely easy and the rpm's will jump really fast untill about 5500 rpm's and then it just hits a wall, like it's hitting a rev limiter. Something doesn't seem quite right to me, once it reaches a certain psi or rpm range the rpm's seem to jump way faster than the car is accelerating. Imagine suddenly throwing the car in neutral while still holding down on the gas as you're cruising down the street, it revs pretty similar to that.
I have no clue what the problem could be, the car drives perfectly even with boost untill I really hammer it/reach a certain rpm range. I have a feeling the car is running a little rich, I'll get some puffs of smoke when I build decent boost and then let off even though my bov is recirculated. Not sure if running rich would have anything to do with those symptoms though.
wackawacka
Is your clutch slipping?
invain
I don't think it is.
wackawacka
The only reason I can think of for a the engine to be revving at a disproportionate amount to the acceleration of the car itself is slipping clutch... unless your spinning the tires.
Im not sure what the 5500 rev problem would be.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
its gotta be a clutch. thats the only way for the motor to be moving faster (per rpm/mph) than the car...
ThuG LyFe
Car: 95 S14
yea if you feel no acceleration even when the rpm jumps up it's your clutch slipping. if you are on oem or old clutch it might not be a bad idea to upgrade to something stronger.
