kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Wed Sep 30, 2009 11:45 am
Just don't use cruise control, it's not the speed but throttle that shouldn't remain constant, so on the highway you need to vary the throttle, on/off every 10 minutes or so, which will affect speed of course, but it's the throttle that you need to focus on, push down say half throttle, then fully release, then repeat a few times every 10 minutes. This is very important for your piston rings to seat properly, if you don't do this your engine could never break-in properly sacrificing efficiency, power and burning oil prematurely, or it could just take longer to break in.
Nothing to get worried about, but be sure to follow the break in recommendations in your owners manual exactly and you'll be fine.
