It definitely might be a candidate for replacement.slinger5150 wrote: Is my thermostat not opening soon enough?
IME, on a warmed-up Y33, the normal gauge position is almost perfectly VERTICAL (or 12:00). Even in very hot weather, it will move only a barely-visible amount beyond this spot.Q451990 wrote:Your gauge should be exactly horizontal or at 3:00 at normal operating temperature.
The gauge is definately oriented differently on the 97-01... here's a pic I borrowed on eBay. Yes, I would say 12:00 on this type of gauge would be normal. No way to know for sure without hooking it up to a Consult to see the actual temperature.slinger5150 wrote:You might mean 12:00. If my gage went to 3:00 the motor would probably seize. My gage starts at 9:00 and goes to about 2 or 3.
