running heater hose in rb install
skwertle
Sup yall,
I was wondering if anybody had pictures of how they ran there heater hoses in there rb25det installs or if you can somehow describe it to me.
Pictures of any other lines/hoses that i will have to connect will be a big plus too.
Thanks
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
If I remember correctly i used the RB heater hoses and they fit?
look under members rides section for my pictures. That may help you see how the hoses ran. I had a problem with my upper and lower radiator hoses, and had to spend a couple of hours in Autozone digging through everything they had to find some that would fit right (after mild trimming).
skwertle
my hoses were on the rb were cut. I was wondering if there was a place were i could get like elbows. i don't even know if they make heater hose elbows.
HybridOne
Car: swaps
my heater hose on the RB is smaller than the heater hoses on my S14. I had to run a reducer to get them to fit. It's odd that the S14 with the KA would have larger heater hoses than an RB.
skwertle
HybridOne wrote:my heater hose on the RB is smaller than the heater hoses on my S14. I had to run a reducer to get them to fit. It's odd that the S14 with the KA would have larger heater hoses than an RB.
from what you said, i'm guessing you just bent the s14(ka) hoses into the rb and there were no kinks?
Joe
just go get the same diameter hose form autozone and run them yourself, you dont need prebent ****.
xjon
Car: 99XJ, 93 240coupe
If you don't care like I didn't I found a heater hose at autozone that was bent 180*. I just stuck it into the engine block and bypassed the whole in-cab heater pipes.
I figured, I don't have the PS or the AC already, screw the heater also.
skwertle
went to summit and found this stainless steel heater hose kit. should this work?
http://store.summitracing.com/...39706
Joe
dude why? you dont need that ****.
NISMO_RB25
xjon wrote:I figured, I don't have the PS or the AC already, screw the heater also.
:ylsuper
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
xjon wrote:If you don't care like I didn't I found a heater hose at autozone that was bent 180*. I just stuck it into the engine block and bypassed the whole in-cab heater pipes.
It's cool to be hardcore and all, but leaving the heater out of the loop could be a big mistake. The heater is a good safety net if your car was to start overheating.
xjon
I know and thanks rbsileighty. I had to do that a few times with my KA.
