Running Extremely Lean After Enthalpy ECU
NICONick
Car: 1993 S13
Hey guys, been in talks with Martin over at Enthalpy but thought I'd turn to the forums for some insight. My current setup is as follows:
T3/T4 Turbo
370cc Injectors (stock SR)
Z32 MAF
Walbro 255
Stock Internals
ECU is tuned for T25/28, 370's, Z32 MAF, 91 octane
After installing and wiring up the new ECU and MAF car starts but runs completely rich on the AFR... Not sure if these ECUs run on an open or closed loop? Also, if have a faulty knock sensor (code) would cause it to pull the timing enough to run completely lean like this?
Here is a video of current running conditions: https://www.youtube.com/watch?v=Aqt1dii ... e=youtu.be[/url]
