Jonny 290 »
https://forums.nicoclub.com/jonny-290-u11793.html
Mon Dec 08, 2003 8:06 pm
I *was* planning to run an Apexi SAFC, but am leaning towards the e-manage the more I read about it.
First of all, the timing correction is key to me. I'm kinda building for 12psi right now, though I'm only planning on running 5 to 7 after the initial install, with the upgrade coming after forged pistons and 550's.
I don't have a working laptop at the moment...an ancient P133, but it's not worth much.
You don't have to tune anything EVERY day, and you can run rs-232 cables up to about 25 or 30 feet. so, you could theoretically park your ride close enough to your pc to just run the cable out the window.
it's nuts, but it works.
otherwise, i bet you $10 you could borrow a laptop for a day, in exchange for a sixpack or something like that. tune it, stuff it in the glove box and go drive home.
honestly, if you want to look at cost/benefit ratio, the only thing that is TRULY worthwhile is a standalone. i'm seriously considering trying to pick up an old Tec2 or something.
