Eddie wrote:Slider I use to feel like an outsider because I only had around 100 posts in almost 3 years. It's comforting to know that there are other nico veterans with few posts.
Yeah I signed up here when I was looking for a 240sx, all were beat to crap. Ended up with an old Maxima, it was totalled 2 years ago. I'm Nissanless now, I just lurk around here.
C-Kwik wrote:I'm not sure how you think this will help with evening out tire wear. If the tires are wearing on the outer tread and you simply switch the tire to the opposite side, it will still leave the outer tread on the outside. Unless the tires on one side of the car is wearing faster, I can't see this doing any good. Flipping the tires on the wheel then switching sides would even it out much better.
Oh man I'm an idiot for some reason I pictured it totally wrong in my head, thought the outside would be on the inside now. My bad
AZhitman wrote:^ Correct.
ALso, according to a "reliable" source, after the first 40% or so of their life, directional tires actually function better reversed. You may want to verify this with someone - Maybe Chet or Chano can clarify.
I don't know about running them backwards being better though unless it's in the dry. I think the thread is designed to prevent hydroplaning and push the water out, wouln't putting them backwards mess that up?
