Frank’s Generator wrote:... The quality of ground that I found as measured between the steering column metal components / the associated electrical circuits in and around it as compared to the battery negative post was excessive. I actually had 15 ohms...
Thanks, you are probably on the right track. I found a 4 ohm difference from the steering column to ground, and from the ground on the tilt/telescope switch and ground. That might very with position, but I don't know.
I ran an extra ground wire to the steering column. When I ran the mode 5 test this time it did not blink any trouble code. Maybe the problem is fixed!
If I never post to this thread again, then that means success.
