centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Wed Aug 31, 2016 3:56 pm
Sure thing. I was thinking about it more last night. I believe there is a way to change the signal from the O2 sensors if you take the cats out. I mean, besides reprogramming the ecu to work with the new signal measurement from regular O2 sensors, you can get a dummy sensor that sends a fake signal to the ECU. Then the car would run fine with no check engine light. The exhaust would smell more, because it's not getting converted, and it would be a bit louder as I said before. You would not be able to pass any inspections, if you have them over there.
But, I really do not recommend it. You would be running full exhaust pollution to the air and your gains are very small (just a couple of horsepower, some have even said they noticed nothing and those people did it to V8 engines). And as I said, horsepower gains are higher up in the RPMS (see a dyno chart). It's not a good trade off. If you bought an intake system, some exhaust headers or even a cat back exhaust, you could gain more horsepower and not have to worry about pollution.
