Running but not right.
roamaver
Car: '91 240sx se HB
Ok I've got my car running finally. But now it wont rev past 2500 rpm. Ok thats simple theres a problem with the MAF somewhere. But I cant figure out where, I'm wondering though, when using a z32 MAF is it absolutly nessecary to get the retune? I mean I have a s13 blacktop all stock. I think my problem lies in the wiring, and I've looked for info on this beofre but couldnt find much..The z32 MAF plug comes with four wires, one signal to ecu, 2 ground, and the others is 12vAC. but the harness only has one ground. Now i tried just leaving one of the grounds out. The engine would sputter and eventually die out, BUT it would rev past 2500rpm. And it would do the same when I put the two grounds together with the ground from the harness. So before this starts making any less sense if anyone has any ideas I'd appreaciate it! thanks!
SnakesKoop
Car: 91 S13 coupe (white) & 2000 Subaru Impreza 2.5RS (red)
yes it is nessicary to get it retune after changing the maf
roamaver
But will it be able to run right without getting the retune??
Rosco
Car: 91' SR'ed Hatch
nope...you need either the ECU-re-tune or buy a used SAFC2 on ebay and you should be good after that. The Z32 MAFS sends a different signal to your ECU and the ECU can't recognize without being fooled (SAFC2) or being re-tuned (ROM tune).
roamaver
damn... well whats the easiest way to get the re-tune? can shops around towns do it or only specific tuner shops or what?
Rosco
It would be cheaper and probably quicker to just get an SAFC2. ECU ROM-tunes and your looking at sending your ECU away. It's kind of pointless to do any ECU ROM tuning until/unless you have some serious mods done to the car....Otherwise like I implied before it's kind of a waste to get your ECU ROM-tuned for just a Z32 MAFS....You could just rewire a SOHC MAFS and be done with it.....It's kinda pointless to be running a Z32 MAFS if you don't have any other mods, so you won't be missing anything. Just save it for later.
roamaver
Thanks for the info man, I just talked to this guy down in Ohio whos a got SOHC maf fs. ROAD TRIP! lol
x240xdrifter
Car: 1991 Nissan 240sx
hey bro, any luck? keep me posted
roamaver
Yeah dude, she ran right after i put that maf on. Now I've got a mystery noise. I've been told it could be spark knock? Anyone ever dealt with that before? It only seems to make the sound when its revving up and no other time..
