IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Mar 12, 2004 6:34 pm
ok, avgas has additives so that the motor will run good at high altitudes and very low temperatures.
also, low lead avgas has just as much lead as leaded auto fuel used to contain.
avgas in a car will destroy the oxygen sensors, ruin the catalytic converter. also, the mixture for avgas is different than auto fuel. the a/f ratio will be off, so if the ECU isnt tuned for it, you may risk blowing the motor up if used continuously.
