elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Sep 30, 2006 7:26 am
dry sumps are great in practice but for long term reliability i prefer the good ol mechanical oil pump... i get nervous when i have electric pumps moving my fluids... much more of a chance that an electric motor is gonna fail rather than a mechanical pump/belt/chain to fail.....
really all youd have to do is make a new sump for the oil pan and readjust the pickup, and you can use everything else that came on the car....
Slim has a 8.5 quart setup on his VH45, with a rear sump pan... its a really cool, and VERY SIMPLE design.... he moved the sump to the rear of the motor, and it has a lot more room... the way he designed is the bottom of the pan is shaped like a bowl rather than being flat... plus its baffled like crazy. he said the only time the engine wont get oil is when its upside down!!
slim is also running a small oil cooler since he had to install a remote filter anyway.... i think if i remember right its a stacked plate (from B/M probably) and its only about 3-5 plates tall... so its not very big.... he has it located where the intercoolers are on a Z (since he has a FMIC), on the passenger side i think....
Thermostats + oil make me VERY nervous... your motor can last a while without a flow of coolant under certain temperatures, but it sure isnt gonna last without oil!!!! i know all the science behind it, but still having a known restriction in an oil line makes me shakey!!!
IMO a dry sump is probably the best way, but i think by increasing the volume you get pretty much all the positive benefits and you keep things fairly simple....
its not hard to install a temp sender in the oil pan.... if you need to lower your oil temps, then install a cooler, but i probably wouldnt put a cooler on to begin with... and if i did run a cooler id probably run it as a heat exchanger, not a seperate cooler....
if you notice on the B/D body chevy's that had factory oil coolers, they placed it behind the bumper core support... FWIW.
