Running an aftermarket Tach....
streeteg
Already searched and I am new to Nissans so I dont understand some of the terminology----
I know the signal comes out of Pin 7 but I dont know what that means
Also I have heard the word CAS used a few times.... help a nissan newbie out...
Car is an RB25 Z
s13point5
Car: 89 240sx
you take the signal wire from the tach and you splice it into pin 7. but why do you need an aftermarket tach. your stock one should suffice
CAS = Cam/Crank angle sensor
streeteg
The car is a 74 Z with a custom Dash and an RB25 swap. Currently there is not stock tach and this will be my only. also +1 for a shiftlight...
Tomorrow I will be taking apart the dash and figuring out the wiring to the best of my ability.
Dumb questions but---- which one is pin 7 lol?
(FYI I have been working on cars for years I was just primarily into the Honda game--- so I can tell you anything that has to do with a B series but its going to take me a bit to warm up to the easy details of a Nissan....)
s13point5
Car: 89 240sx
pin 7 on a RB ecu would be the same pin 7 on a honda ECU theoretically. you just find a pin layout of an RB ecu. im sure i can look in the FSM when i get out to the garage and find it for you and post a picture. how do you know its pin 7 tho?
p.s. im a honda boy still at heart. ive owned 4 swapped EKs (i ONLY drive EKs haha) i still drive one as my beater/daily driver
s13point5
Car: 89 240sx
okay so i did a little research for you. i dont know where you got "pin 7" from but that pin is blank on the RB ecus. the pin you are looking for on the ecu is pin 35 and its yellow with a blue striped wire. i havent looked at my own RB ecu to confirm this yet but i think they are right. hope this helps.
zdrifter
Car: 1978 Datsun 280z
If you go with an autometer tach you need to get a tach adapter and splice the tach adapter by cutting the white wire going to the ignitor and putting the adapter between the wire you just cut, install your gauge and make sure you have the wires cut for a six cyl.
streeteg
Thanks guys! I am going to attempt to do it today....
here is my old honda that I sold to get the Z....
streeteg
any news on the yellow with the blue striped wire? there is one coming out of my ecu that does not go to anything so I am tempted to try it...
DJButton
Car: 2010 Nissan 240sx
I'm jealous I should have kept my Honda for a daily...
s13point5
Car: 89 240sx
DJButton wrote:I'm jealous I should have kept my Honda for a daily...
stock motor currently averaging 38 mpg . she is gonna stay stock motor because i have the 240 as the "fast" car. i know not alot of people like hondas but i think my daily looks good
streeteg: dope EG hatch
streeteg
s13point5 wrote:okay so i did a little research for you. i dont know where you got "pin 7" from but that pin is blank on the RB ecus. the pin you are looking for on the ecu is pin 35 and its yellow with a blue striped wire. i havent looked at my own RB ecu to confirm this yet but i think they are right. hope this helps.
that wire didnt work---where else can i draw a signal for the tach?
streeteg
Anyone? I still need a signal for the tach.....
Sil240
Car: Nissan S13 "The One Cam Wonder"
If you go under the hood, on the wire harness there is a little plastic cylinder with a cap (there's actually 2 of them, the one with the yellow wire/redstrip) But that wire shouldn't work if you have no pulse coming out of pin 7 on the ecu.
I'm in the same boat as you are.There is something messed up in your wire harness.
Mine did work but then it was re-wired to make the engine work but now no more tach signal. POOOOOP!!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Pin #7 is not blank on RB25 ECUs. Pin #7 is blank on the M63 plug on the RB harness, so maybe that's where you are confused. The tach signal wire runs from pin 7 on the ECU to pin 35 in the M63 plug. Yes it is Y/L (yellow w/blue stripe).
SIL-LINE
Car: S-13 With RB20det
if you look at the ecu plug (looking at it from the side with all the wires sticking out )
from right to left there are three 20 prong slots and one 16 prong slot. on the side that has the 16-and 20 (from bolt to the left) the top row number four is your rpm signal.
see if this works , this is from my SAFC pin diagram so it should work out ...
good luck .....
240wootie
Car: 1989 rb20 coupe, 2002 WRX
I have a '96 EK hatch i bought a few weeks ago, ZC swapped, carbon hood, einkei's, and real coilovers. not a bad daily driver. it was soooo freakin loud when i bought it. i had to drive 3 hours to get it home... i drove for 30 min, then stopped and got ear plugs, lol. its much better now. hope to get my rb20 coupe running here pretty soon... when i get time to sort out the wiring harness, lol.
streeteg
Wiring is just a big maze... I dont mind doing it but at least on a honda it utilized stock harnesses so it made tracing the wires that much easier. Not to mention I did not do this swap myself so having to go over anothers work is difficult. Either way I will try the suggested and hopefully get a signal soon. ...
Thanks for alll the help. if this doesnt work there will be pictures next to my questions on the next round
